Bestsync 2011 not startup
ekekakos
Post by ekekakos »
Team,
I have install Bestsync 2011 on my laptop which has WIN7 ULTIMATE 64 but when my machine startups the application did not startup automatically. Can you tell me what to do?
Thanks in advance,
Elias
Re: Bestsync 2011 not startup
If you have setup the startup privilege to "Administrator", Windows 7 UAC will block BestSync from running automatically.
Please start BestSync, click the "Option"/"Option" menu, uncheck the "Start BestSync when windows starts" option in the "General Option" dialog box.
And use the "Schedule manager" in the "Administrator Tools" of the "Control Panel", setup a schedule to start BestSync when user logon, and set the "Security Options" to "Run with highest privileges". Here is the tutorial:
http://www.vistax64.com/tutorials/13290 ... -task.html
The command line to start up BestSync likes the following:
x86 (32Bit) Windows:
"C:\Program Files\RiseFly\BestSync 2011\BestSyncApp.exe" /trayicon
x64 (64Bit) Windows:
"C:\Program Files (x86)\RiseFly\BestSync 2011\BestSyncApp.exe" /trayicon
