can't save multiple task with the free version
jeanmarc
Post by jeanmarc »
I am testing BestSync with 3 tasks but only the first one seems to be saved. is there a limitation with the free version ?
Jean marc
Re: can't save multiple task with the free version
BestSync Free Version does not limit the task number, file number and folder number.
Please check if you are using the latest version.
