My data alway delete when I sync it!
thanhhung1324
Post by thanhhung1324 »
Hello!
I use bestsync 2009 to sync data ftp server to my PC. My data is folder include some older file and new file
( example:
folder 1: file 11 ( older)
file 12 ( older)
file 13 ( new)
folder 2
file 21( older and same file 11)
file 22( older and same file 12)
file 23 ( new)
When I sync folder 2 from FTP server, file 21and file 22 ( older) is deleted. That is not good because some program need it to process.
How to fix it?
Re: My data alway delete when I sync it!
May be you have deleted file21 and file22 from Folder1, so BestSync try to delete the deleted files.
If you do not want BestSync to delete the deleted files in other side. You can select the "Do nothing" in "When a file in one side is deleted, select the action to do" options in the "Delete" setting page.
