Can Best Sync Sync Data from MS Sharepoint 2.0
Starfire
Post by Starfire »
Hi All,
Does anyone know if Best Sync can Sync Data from Microsoft Sharepoint 2.0 to a Local HDD? You would be life saver if you can provide this if info
Best Regards
Re: Can Best Sync Sync Data from MS Sharepoint 2.0
BestSync does not support HTTP protocol now, may be you can search the web to see if there is any way to mount the Microsoft Sharepoint 2.0 to a drive.
Such as the Freeware NetDive:
http://www.netdrive.net/
