Trying to Delete Missing Files on Remote Server
broctune
Post by broctune »
I'm running the trial version of BestSync on a web server. It is mirroring the file system over FTP to a web server off-site. Everything seems to be working well but I keep seeing the same transfer failures showing up in the logs as:
... FTP Error:550 /folder/_bestsync_tmp_XXXXXXXXXX_filename.gif.bs_: The system cannot find the file specified.
The BestSync temporary files in question were manually deleted from the remote server after an error. These files do not exist on the source or remote server but BestSync has been trying to delete them for several days.
Is there any way to fix this? It is creating a lot of traffic to our remote server.
Thanks,
Dave
Re: Trying to Delete Missing Files on Remote Server
Please check if you are using the last version.
Please do not delete the temporay files manually when Bestsync is synchronizing the folders.
Bestsync will delete these temporary files after synchronization.
