could not stop bestsync folder sync
lccseh
Post by lccseh »
i tried a test today, syncing a set of folders with about 50,000 files / 50gb total on a reasonably fast w2k8 server with mirrored drives.
the sync seemed to be slowing the server down, so i tried stopping it, but could not. even with task manager, after lowering the priority, i still could not get it to stop - so had to terminate it.
any suggestions?
regards,
les
Re: could not stop bestsync folder sync
Please check if you are using the latest version(6.3.36 later). BESTSYNC has fixed a similar problem from version 6.2.
lccseh
Post by lccseh »
i believe it is - when i downloaded it from your site yesterday that is the version shown on the site.
the problem seems to be if i have the preview window open.
btw, how do i check the version? i could not find it using the usual methods.
regards,
les
Please try to uncheck the "Process multiple files simultaneously" option in the "Copy options" to see if the problem can be avoided.
