bestsync not including files in sync?
lccseh
Post by lccseh »
after an initial full folder->folder sync yesterday, i was looking forward to seeing how quickly bestsync would determine what had changed in doing a sync tonight.
but it ignored many files that had definitely changed.
am i correct that if on the filter tab i have *.*, then all files in the specified folder(s) will be checked?
and if i do NOT check "only files changed after(in) following time, then it will compare all files between the two folders?
thanks,
les
Re: bestsync not including files in sync?
Please try to select *.* in the "Filtering" setting, and donot select any timestamp filtering.
