Is it possible to open a project (of about 10 tasks), start it on the first task and have BestSync automatically start the next task on the completion of the first ...WITHOUT creating a schedule?
I only one one task to run at a time.
Thanks for any help.
Don
Automatically start next task without schedule
Re: Automatically start next task without schedule
You can use the "Application" setting to run multiple tasks after the task is synchronized.
Please refer to the attached grphics.
- Start Next Task After Sync
- StartNextTask.png (39.52 KiB) Viewed 10047 times
- Task ID
- TaskID.png (45.31 KiB) Viewed 10047 times
OUTSTANDING! You guys are the BEST!
Don
Don
