Amazon S3 with BestSync 2012 Beta
davidizadar
Post by davidizadar »
I tried the new BestSync beta trying to connect to our Amazon S3 Bucket, but the connection always fail with message
Error-:Failed to create CLOUD interface.
When will this feature be available?
David Izada R
Re: Amazon S3 with BestSync 2012 Beta
The error is because the COM interface of Amazon S3 component has not been registered correctly, please try to run "regcloud.bat" once in the installed folder of BestSync 2012 to see if the problem can be resolved.
tgreenlaw
Post by tgreenlaw »
I had the same issue with the CLOUD interface. I ran regcloud.bat, but it couldn't find regasm.exe, so I edited the batch script to run the line in regcloud.bat for every version of the .net framework I have on my PC.
That didn't fix the problem either. It registered correctly in v2.0.50727 and v4.0.30319. I restarted both the service and the app, but I'm still getting the same error.
I hope you have something else we can try, because I need to pick an S3-based file sync for Windows by tomorrow afternoon :D
Have you try to install .NET 4.0 redistributalbes before install Bestsync?
We have fixed a problem related to this question,Please download and try version 7.0.26.
