Cannot Delete Task
trevorblanc
Cannot Delete Task
Post by trevorblanc »
I created a few tasks for testing. I moved one of my Tasks from the Task List over to "Run as Service"
Now I want to delete all my Tasks and start from scratch. The Task I move to "Run as Service" won't delete.
If I click delete it disappears but the next time I start Best Sync it returns.
I tried moving it back to Task List and deleting it there.
Same thing. When I restart BestSync it returns.
I tried starting new project. Same thing.
Re: Cannot Delete Task
Please check if you are using the latest version (7.0.19) of BestSync, We have fixded a bug about this problem from version 6.1.11.
trevorblanc
I have version have 7.0.1.8(64bit)
So what do I do now?
I have tested on my 64 bit Windows 7, but can not recreate this problem.
Please try to use the administrator privilege to start BestSync, and remove the task again.
