Buffer Space issue
matthewedwar
Buffer Space issue
Post by matthewedwar »
We have recently updated Bestsync to the lastest version and switched to a 2 way sync. Since doing that we have started to receive the following error
[1]winsock:Receive::Error.:error:(0x00002747):An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
As a result certain files are not found on the FileZilla server end. The scan is causing them to be deleted.
Help Please!!
Re: Buffer Space issue
I have searched for the winsock error 0x00002747 (10055 or WSAENOBUFS), it seems that the error is related to the OS.
Such as the following Microsoft Support:
http://support.microsoft.com/kb/196271/en-us
Or may be you can try to avoid the problem by "Speed Control" setting setting of the sync-task, to limit the uploading speed.
For the error causes the file be deleted, we'll try to fix this problem.
