Sync failures
dataman
Sync failures
Post by dataman »
I am trialing Bestsync, there is around 80 gbytes of data to my ftp site. The last run gave 200 successes and 8 failed. Is there a log I can look at to see what files have failed and why?
dataman
Re: Sync failures
Post by dataman »
I just checked that VSS was started and it was not. This might explain the failures - I have now started VSS. I still need to see the reason in a log though, and the log Bestsync had created didn't give this.
Re: Sync failures
If you can not find the record in the task log, you can try the global log by "Option"/"View Log FIle" menu.
