On two separate computers, when trying to sync some large file (3-4 x 1gb files) with my work SFTP site, either with 8 or 16 connections, I have a situation where the amount of RAM that bestsync requires suddenly shoots up to 98% +, stays there for a while, and then eventually windows kills the program because it is hogging too many resources.
Why is the program requiring such massive commitment of RAM just to copy some files off FTP? It's an i7 PC with 6gb of RAM - that should be sufficient.
Is there any way around this problem, because it's currently unusable?
I'm using the latest version, and am still on a trial
cheers,
Richard
major RAM issue
Re: major RAM issue
We have confirmed on version 7.3.02, the new version works fine when upload two file that are larger than 3.5 GB.
Please try the new version .
Re: major RAM issue
Is there a known issue with large files then? Because I regularly deal with very large files,
Thanks,
Richard
Thanks,
Richard
Re: major RAM issue
May be the old version have problem when upload large files, But I have tested on the new version, the new version works without any problem.
Re: major RAM issue
Sorry I am still having issues with this. It is not restricted to large files - the last 3 days in a row my backup has crashed Goodsync - the usable RAM has shot up to nearly 16GB (my total system RAM) before inevitably crashing.
This must be a bug. The total quantity of files is not even 16GB that I'm transferring, and even huge projects that I work on for work, on other progrmas, do not require more than 4GB of RAM. I am running the latest version of Goodsync.
At $99 the full license is not cheap, so I need to know this software works correctly and is not buggy. At the moment, I have to conclude that any program that hogs 14gb of RAM has a bug of some kind.
Please let me know what we can do to rectify this problem
- RAM.jpg (10.13 KiB) Viewed 10033 times
Re: major RAM issue
Sorry we can not recreate this problem.
Could you please export the task setting to a file, and send it to risefly(a)risefly.com.
So that it can give us something hint to investigate the problem.
