Realtime logging
24Seven
Realtime logging
Post by 24Seven »
One feature that I would like to see real time logging. I want to be able to see what the sync is doing while it is doing it to have a better idea of problems it might be having. This is especially true when using S3 synchronization.
Re: Realtime logging
If you want to see the log, you can start the Preview of the task, there is a log window below the file tree.
The log displays the sending commands and the responses from the S3 server.
