How do i setup a task to synch multiple sftp servers?
kishore
Post by kishore »
I have this requirement where i need to synch my local folder to multiple SFTP sites. Is there way to get this done using BestSynch?from the task i can only specify one SFTP site.
Any suggestions please?
mcjathan
Re: How do i setup a task to synch multiple sftp servers?
Post by mcjathan »
Multiple tasks may do the trick.
In each task, folder1 is your local folder and folder2 is a different SFTP site.
Will that do what you want to accomplish?
kishore
Post by kishore »
Thanks for your reply. I ended up doing the same. :)
