Ignore 1 hour difference - how
shx
Post by shx »
I have 2 folders that I am comparing. Because one computer clock was not set properly, everything in one folder is an hour later then the other folder. and Bestsync flags them as changed even though they are the same.
Is there any way of saying to ignore the 1 hour difference. Both of these folders are located now on the same computer.
Steven
Re: Ignore 1 hour difference - how
You must set the time clock of the computers be correct, otherwise the tasks can not synchronize the files correctly.
shx
Post by shx »
thanks
alan9876
Post by alan9876 »
It might be a tremendous benefit if BestSync could accommodate a 1 hour discrepancy due to Summer / Winter clock changes.
Ten years ago the I.T. department governed the company network and servers as a communal resource.
Our department had Windows XP.
I do not know what version of Windows / Unix / etc was running the servers,
But I do know that when the clocks went forwards or backwards the result was a major headache,
because the timestamps on the P.C. files corresponded to BST and the Server files were GMT or vice versa,
hence when I synchronised my PC to the server I had the pain of 10,000 files that were "changed" and I had to locate the 3 or 4 files that might have modified contents.
Regards
Alan
BestSync has an option called "Ignore file date&time changes that are because of Daylight Savings Time(DST) changes".
Like the attached bitmap. Please try the option.
[attachment=0]DstTime.png[/attachment]
Ignore Daylight Savings Time
alan9876
Post by alan9876 »
Many thanks
Regards
Alan
