Delete BestSync Project Files that End with *.fsf~ & *.fs~~
mcjathan
Post by mcjathan »
Jean-Pierre,
In the folder where I store my BestSync project files, I've notice a number of files that end with *.fsf~ and *.fs~~. Is it OK if I delete these files?
Regards,
Re: Delete BestSync Project Files that End with *.fsf~ & *.f
Jeff,
These files are backup files of the task setting files, in case the setting file is crashed, BestSync can recover from the backup files automatically.
If you delete these files, BestSync will create them again when you modify the task setting and save it.
BestSync regards
