WebDAV-Sync with German characters ü, ä, ö
Roli60
Post by Roli60 »
Hi, I try to use Best Sync 2012 to sync data in my cloud storage HiDrive (Strato, a German Provider) with my Win7 PC via WebDAV. All is working fine except folders and files with german characters ü,ä,ö. It's not possible to open Folders and files with these characters after transfer into the cloud. I assume it's a problem of the right code page (utf-8). May I configure the WebDAV interface to handle these characters? Thanks for your fast answer.
regards
roli60
Re: WebDAV-Sync with German characters ü, ä, ö
Please check if the WebDAV server supports UTF8. BestSync uses UTF8 to communicate with the WebDAV server, and should be able to process these kind of characters.
Roli60
Post by Roli60 »
Thanks for your answer. I checked different configurations on my PC and found that my Cloud browser was not configured right. After correction all is working very well.
Regards
Roli60
