Versioning
starweb
Versioning
Post by starweb »
Hello. I am playing with versioning and I'm not sure it is working correctly. I turning it on by enabling "Backup archiving system" and it's set to "Date String of the starting time". I set it to "Real-Time Sync" and it put a copy of all my files in the backup folder. I then changed a file and waited to see if it backed it up. Sure enough, it backed up but it just overwrote the previous file of the same name within the backup folder. Shouldn't this have created a "version" of that file so that I would now have two versions of that file in the backup?
Starweb
Re: Versioning
In real-time mode, BestSync switch the backup folders in about 1 hours, so 1 hour a version. (Please use version 7.3.30 later, the versions before this version switches backup folder in about 8 hours, so 8 hours a version)
If you need to backup all the changed versions, please stop using "Real-time sync", and specify "Date and Time String of the starting time" in the "Versioning -- Create sub-folder ...." .
