I'm trying BestSync to backup an FTP server of one of our client (UNIX machine) and I have Windows 7.
It seems everithing good but I find some folder, made by our customer, with a final dot (like \Software.\ ). I cant' ask him to rename all folder and remove the dot.
BestSyn create the folder under Windows7 but the folder is not accessible and not possible to rename it.
I think W7 doesn't like folder with a dot and in effect if I try to manually create a folder with a final dot the system create the folder but without the dot.
Do you have any suggestion or turnoround?
thanks a lot from Florence (Italy)
Issue with folder name that ends with a dot
matteo.nannini
- Example of folder on the FTP server
- Cattura.PNG (3.18 KiB) Viewed 6600 times
- Example of error on PC local folder
- Cattura2.PNG (44.37 KiB) Viewed 6600 times
Re: Issue with folder name that ends with a dot
We'll try to avoid this problem in BestSync 2013. Please wait for one or too weeks for the beta version.
Here is the beta version of BestSync 2013, the new version can copy files/folders that end with dot in name.
32 Bit:
http://www.risefly.com/2013/BestSyncSetup.msi
64 Bit:
http://www.risefly.com/2013/BestSyncSetupX64.msi
Please confirm if the new version can synchronize with your server.
Best Regards
32 Bit:
64 Bit:
Best Regards
