FTP Error:200 Type set to I.????????
Henrik4223
Post by Henrik4223 »
When my sync runs some of the files (both .mp4 and .jpg) result in an error (FTP Error:200 Type set to I.) - I cannot see any system in the errors and it seems random. However, the files that gives the error will not syncronize with the server.
Anyone has any ideaas?
Re: FTP Error:200 Type set to I.????????
Please try to set a bigger timeout value in the task setting, such as 180 seconds. It seems that the response from the FTP server does not match the command.
james442
Post by james442 »
If you could export the task setting to .xfsi file, then send it to risefly@risefly.com, I would like debug this problem.
