My window is is 7 64bit when i add new task want Broswer My Computer C drive but is show only Computer on top cannot click in and Show the dropdown list such C , D drive
but this problem dosent have on my other pc that is 32bit..
so is annoying when i have manual copy and paste the path on the task.
When Add New Task Browser Computer Not Show Drop Downlist
- The Screen That i Take
- Untitled.png (104.52 KiB) Viewed 9804 times
Re: When Add New Task Browser Computer Not Show Drop Downlis
I have installed the Windows 7 (Simplified Chinese) to test this problem, but can not recreate this problem.
Does this problem happen all the time when you browse the local folder?
ya I uninstall Ver8.0.2.0 and install Ver8.0.2.1 still the same all the time only cause in Windows 64bit my other laptop came with 32bit Wiondows 7 does not have this problem
is it the Ver8.0.2.2 fixed this problem?
Version 8.0.22 fixed this problem, please download and try it.
i installed Version 8.0.22 look everything ok now Thanks for the quick Respone for fixing this Problem.
