Stable Version Request
esper80
Post by esper80 »
Gentle Risefly Staff,
I'm using your software to backup two servers containing very important data (I use one-way mirror synchronization...).
I'm using an old version of your software (BestSync FTP 2012 ver7.3.1.0 Ultimate) and it works well.
I tryied upgrading to newer versions, but there was always something that doesn't work well (one time services not start, another time services lock up, and so on...).
I noticed that you fixed those bugs with new builds.
Now my question: can you release a "stable version" of your software?
I think that you should release two versions type: beta version and stable version.
For my purpouses I only need to work with stable versions. It doesn't matter that stable version is older than beta version, but I need to sleep well every night ;-)
Last thing: One time I read this bug fix: "BugFix: Deleting files in target folder may cause the files be deleted from the source folder in real-time mode even in one-way synchronization." :shock: :shock: :shock: It means that my source data is unsafe when using ONE-WAY synchronization using this build????
Re: Stable Version Request
"BugFix: Deleting files in target folder may cause the files be deleted from the source folder in real-time mode even in one-way synchronization." this bug is only from version 8.0.12.
I think the most stable version is ver8.0.21, because the reported bugs are all be fixed, and users have not reported bug for a while. And the new version 8.0XX can verify the files after sync, if the verification result is fail, the new version will retry the synchronization. Please try the new version.
