BestSync is invisible
pixeldroid
Post by pixeldroid »
Hello:
I upgraded to the latest version yesterday and now when I launch BestSync, the interface is invisible.
In the attached screengrab, you can see the icon in the taskbar and then when I launch it, you can see that I can find the app on the desktop and activate the menu - but no UI!
Please advise.
Thanks.
Re: BestSync is invisible
Please try following steps to see if the problem can be resolved.
1. Exit BestSync, then run it again.
2. Try to upgrade the driver of the video card.
