I upgraded to version 8.0.3.3 and am having problems adding tasks. I can add the task in just fine but when the task is saved, the display loses the path infomation about the flow. I've attached 2 screenshots to show what I mean. Screen 1 is setting up the task and screen 2 is how the task looks when I click finish.
When I try and add a network share it looks a little different but still incorrect. Screen 4 shows that.
The task will work even though the file paths looks incorrect. That's shown on screen 5. If I modify the task, the task breaks because the paths are invalid.
adding tasks problem in 8.0.3.3
- screen2.png (53.56 KiB) Viewed 5967 times
- screen4.png (53.86 KiB) Viewed 5967 times
- screen5.png (108.45 KiB) Viewed 5967 times
- screen6.png (70.18 KiB) Viewed 5967 times
Re: adding tasks problem in 8.0.3.3
That you for reporting this bug, we have confirmed that this bug is only in version 8.3.3.4.
Now its has been fixed, please download the version 8.0.3.4.
