Sync 3 computers + network + cloud?
faluxbkk
Post by faluxbkk »
Maybe someone can advise me what the best setup is. I have:
1. 3 computers that I work on
2. 1 network drive
3. 1 cloud backup (JustCloud)
I want 3 computers synchronized so I can work on any of the 3 and have latest data. So I think use network as central distribution, then backup from any to cloud? (It's just additional for last resort, not the most important). I have BestSync Ultimate now so no limitation there.
How do I setup? Network as folder 1 then 2-way on 3 computers?
Thanks for any suggestion
Mike
Re: Sync 3 computers + network + cloud?
You can setup tasks on 3PCs to synchronize local folders to the central network drive in two way.
So any files changed in 1PC, can be synchronized to other PCs.
You can select one PC to backup the synchronized folder to the cloud (Amazon S3, Google Storage, from the beta version, BestSync also supported Microsoft Azure, SkyDrive, Google Drive). or, you can setup all 3PCs to synchronize with the cloud, but this way you may increase the traffic fee.
Best regards
RiseFly Software Team
