Time Zone
starweb
Time Zone
Post by starweb »
Hello. I have a server I want to sync with that is 7 hours off from my workstation to sync to. Is there a way to tell bestsync to ignore a 7 hour difference?
Re: Time Zone
BestSync detects the timezone, and adjust the time automatically.
So you need not to worry about this.
starweb
Re: Time Zone
Post by starweb »
[attachment=0]4-9-2013 3-58-26 PM.png[/attachment]
Why does it think it needs to download files then that are 7 hours off and still have the same size? See attached screenshot.
screenshot from preview
4-9-2013 3-58-26 PM.png (26.06 KiB) Viewed 7232 times
Re: Time Zone
What kind of protocol are you using (FTP, WebDAV or others)?
May be the server is lack of the support of some command for sync the times-tamp of files.
If it is possible, please export the task setting and send it to risefly(a)risefly.com, so we can investigate this problem.
