Jean-Pierre,
I'm currently using BestSync to sync two computers (2-way sync) through an FTP server:
Computer1 <-> FTP Server <-> Computer2
I'm considering switching from an FTP server to WebDAV:
Computer1 <-> WebDAV <-> Computer2
I have some questions about BestSync, FTP, and WebDAV:
1) How does the robustness of BestSync/FTP compare to BestSync/WebDAV? Does BestSync/WebDAV work at least as well as BestSync/FTP as far as error-free syncs, file time-stamping, NTFS file permissions/properties, and over sync robustness?
2) How does the speed of BestSync/FTP compare to BestSync/WebDAV? FYI, with BestSync/FTP I'm currently using 10 threads / concurrent file copies on each task. Is BestSync/FTP faster or slower than BestSync/WebDAV?
3) I'm considering setting up WebDAV on a Windows 7 Pro x64 machine using the WebDAV built-in to the native IIS (for example see this URL: http://tinyurl.com/bchlsx6). Will BestSync work well with Windows 7 native WebDAV? Or, do you recommend some other WebDAV host software?
4) In general, are there any downsides to switching from BestSync/FTP to BestSync/WebDAV?
Regards,
BestSync: FTP vs WebDAV
Re: BestSync: FTP vs WebDAV
Here are the answers of your questions about FTP vs WebDAV:
>BestSync/FTP and BestSync/WebDAV should have the same robustness.
WEbDAV is more firewall friendly than FTP. WebDAV uses only one HTTP port, but FTP protocol uses 1 control port and a n extra data port, furthermore, each download/upload transfer may use a different data port.
But BestSync FTP feature has been tested with many FTP servers, and supports all the commands (MFMT, MDTM, Site UTIME) for copying last modified time-stamp to the uploaded file. But many WebDAV servers (include "Windows 7 native WebDAV") do not support command for copying last modified time-stamp to the uploaded file and list the last-modified time of files in one command, this makes WebDAV not efficient for synchronizing among PCs.
>BestSync WebDAV supports multiple threads and concurrent file upload/download also, its speed is fast, may be faster than FTP. Because WebDAV need not to create an extra data transfer thread, this saves the CPU consumption and resource usage.
>I do not recommend to use IIS WebDAV, because it does not support PROPPATCH command to copy the last-modified time to the upload file, and its PROPFIND command does not contains customized meta-data when list files. May be Apache server is more flexible than IIS WebDAV.
> If you selected a suitable WebDAV server, WebDAV should should has merit over FTP.
