Cannot stop task
elioth
Cannot stop task
Post by elioth »
Hello, I have upgraded from 2012 to 2013 and I have one Windows Mail task which I cannot stop. I select it and click on the stop icon but nothing happens.
If I double click on the task, I get the error 'this task is running, please stop the task before setup it'
I just want to remove the task. Is there any way I can do this?
Re: Cannot stop task
May be the task was blocked by Windows Mail, you can kill BestSync in the task manager, start BestSync again, then delete the task.
elioth
Post by elioth »
Actually, I cannot stop any task after upgrading from 2012 to 2013. I have resolved by uninstalling 2013 and re-installing 2012.
