set size limit
gregbarber
set size limit
Post by gregbarber »
hi,
is it possible to set a size limit on files to be transferred for example I do not wish files over 1GB to be transferred.
how do I go about this
Re: set size limit
There is not a size filtering option now, but you can manually exclude these huge files in "include/exclude" option, or use the context menu of the preview windows to exclude the files (BestSync remembers this setting).
