Hi All,
Anyone try before using Restore function?
I am not able to restore as the Restore function is Dim.
Anyone can help?
BestSync Not able to Restore
- BestSync Restore.jpg (111.59 KiB) Viewed 5848 times
Re: BestSync Not able to Restore
Hi All,
The restore button suddenly enable by click here and there.
Unfortunately after click the restore, nothing happen to Folder 1 and 2.
Anyone can help?
Anyone can help?
I have tested this issue, but BestSync works fine (restore files correctly).
Please check if you are using the newest version of BestSync.
