FTPES synch problem
darius
FTPES synch problem
Post by darius »
I can’t synch files on ftpes modes. BestSync connected to FTPS server and got directory list, but in synch proccess only part directory synchronized. Those files that synchronized does’t open and have strange names like:
“_BS8_QCYC4PXJTHHAC_06B8_01_00_MD5_04FEE5F29103771609561162D24C15DB_IR2GGSLOON2GC3DMFZWG6ZY.BS_”.
In log have some problem item:
<426 Data connection closed abnormally.
>XMD5 "/Foto/100OLYMP/P1010004.JPG" 0 1167210
<250 6C4421499C551F31CB4152CEE6EB30D9
Failed to verify file(MD5).
>PASV
<227 Entering Passive Mode (192,168,1,105,8,99).
>RETR /Foto/100OLYMP/P1010004.JPG
<150 File status okay; about to open data connection.
Data Channel SSL/TLS Handshaking...
Data Channel SSL/TLS Handshaking OK.
SSL:Receive::DecryptMessage.(0x80090308):The token supplied to the function is invalid
ReceiveData timeout.
What is the problem?
Re: FTPES synch problem
Please confirm if the server name matches the name in the SSL certificate.
Please refer to the following page to see if the problem can be resolved:
http://www.fixkar.com/articles/kb/1075/
And this blog:
http://msmvps.com/blogs/bradley/archive ... nager.aspx
