Bug: Bestsync 2014 crashes when viewing log file
Ian Clarke
Post by Ian Clarke »
I am running BestSunc 2014 on three different computers and on all of them, the program crashes if I try and view the task log. I can view the "Options/view log file" and that is ok. If I right click on a task and click on "View Log File", the program crashes and stops responding.
Two of these machines were upgraded from 2013 (which did not have this problem) and one is a clean install.
Two machines are windows XP and one is server 2008.
Re: Bug: Bestsync 2014 crashes when viewing log file
Thank you very much for reporting the bug.
It has been fixed, please download and try the new version 9.0.3.3.
Ian Clarke
Thank you Risefly. Version 9.0.3.3. fixed the problem and I can now view the log files.
