Bug:"Delete the remained files from the other side"NOT works
SherryAU
Post by SherryAU »
Hello Support,
I have a 2ways sync for my FTP server folder and local disk where Bestsync installed.
And I choose the Delete: Delete the remained files from the other side. It works with my previous verion Best sync 2014; however after I recently upgraded to the newest version;
When I deleted those files from the local disk, the FTP server site keeping resend those files again to cause the duplications.
I did choose Delete: Delete the remained files from the other side option under Delete tab, however it doesn't work with the newest version of Best sync. Please advise.
Regards & Thanks
Sherry
Re: Bug:"Delete the remained files from the other side"NOT w
I'm sorry that we can not create the problem, could you please try the newest version to see if the problem is fixed.
