Task never starts
tjblow
Task never starts
Post by tjblow »
Using Bestsync 2014 9.0.3.3. Task is to copy data from network drive to a local drive, renaming it. Job is scheduled to run as a service and run every 5 minutes. Once created can not get job to start with Start Button, Can use preview task to get it to run, (manually?). Is I use the START ALL checked tasks, the tasks synchronizes and transfer the files, but if I wait 5 minutes, when it should run again, the task does not run....
Re: Task never starts
Have you setup the login account of the service and the network folder in the folder browsing dialogbox?
Please refer to the following Q&A page:
http://www.risefly.com/fseqna.htm#SyncNetDriveAsSvc
tjblow
Post by tjblow »
Thank for that information... Task is now running..
