CPU Usage high
hzatph
CPU Usage high
Post by hzatph »
I use version 5.4.36
I have a quadcore PC and Bestsync always uses about 25% of my CPU according to the Windows Task Manager. That seems a lot. Is it right? Thanks.
Re: CPU Usage high
The CPU usage is related to the number of running tasks and files to be synchronized.
You are using a very old version of BestSync. You can try the new BestSync 2015 (beta) to see if there is any performance improvements.
hzatph
Re: CPU Usage high
Post by hzatph »
Thank you. Does that require me to purchase a new licence to use it permanently?
Re: CPU Usage high
If you have license of BestSync 2012 before, then you need to order the upgrade license.
hzatph
Re: CPU Usage high
Post by hzatph »
The current version does exactly what I want it to do ... apart from it now taking up effectively one core of my processor. Why do I need to buy a new version to have a bug fixed?
Re: CPU Usage high
We are improving BestSync constantly, we have added many new functions into the new version.
Please support us.
