Android tab missing under File Systems
pqhost
Post by pqhost »
Hello i do not see an "Android" tab under file systems. I wanted to set it up with BestDav. Can you please assist?
Re: Android tab missing under File Systems
Android synchronization feature is from BestSync 2015 (beta).
Please install BestSync 2015 (beta) to use the feature.
pqhost
Post by pqhost »
Thanks yes i did. I can connect but i just get a lot of errors when trying to upload files to my device
Could you please tell me what kind of errors happened when upload the files?
