Does BestSync support binary file comparison and VSS?
i-Ask
Post by i-Ask »
Does your product support binary file comparison and VSS?
Re: Does BestSync support binary file comparison and VSS?
BestSync can verify the file (binary comparsion or MD5 check) after copy it by the following option:
[attachment=1]verification.png[/attachment]
And BestSync supports VSS by the following option:
[attachment=0]VSS.png[/attachment]
To use VSS option, please run BestSync 64 bit on 64bit OS, or BestSync 32Bit on 32bit OS.
And you need to set to "Run as Administrator" option in the auto-start option.
Verification
Verification
VSS Option
VSS Option
