Can I copy files by USB, then synchronize them by BestSync?
i-Ask
Post by i-Ask »
We want to sync our 2 TB data. It is located differen city. If we copy this data our location then start best sync is it work. Or how can we copy initial data? Than we want to sync data daily.
Re: Can I copy files by USB, then synchronize them by BestSy
If the file system supports setting the time stamp after copy the file, then you can copy the files using Windows Explorer by USB drive , then setup a task in BestSync to synchronize the two folders.
If the file system does not support setting the time stamp after copy the file, you can also copy the files by USB drive, then use BestSync to synchronize the folders. But before you synchronize the task, press the "Action"/"Customized Preview"/"Synchronize Timestamp Only" menu to synchronize the timestamp once, after that, BestSync can synchronize the changed files only.
