Using google drive to (twoway) sync across two computers and after syncing the excel file has "unreadable" content and needs to be "recovered."
Ascii files seem to work ok. Is this a bug, or is there some setting that needs to be changed?
Thank you.
problem with "unreadable" excel files after sync
Re: problem with "unreadable" excel files after sync
I have tested this issue by BestSync 2015 (beta, download from the download page of risefly.com), the result is OK.
Please try the version to see if the problem can be resolved.
No, still this does not work.
Have you tried to synchronize a new excel file by the new version?
