HI There
I have several tasks run under scheduled tasks to transfer files and create log files.
This weekend we had a automatic update of the time service on the server due to daylight savings.
This caused one of the scheduled tasks to "get stuck" and lock all the following tasks, preventing them from running.
Is there any way to take into account changes in daylight saving changes ? perhaps to suspend tasks on certain days between 11.55 and 1.30 am in the last week of the month when daylight saving comes into effect ?
My tasks are set to run every 3 mins, 5 mins, and 13 minutes at the moment.
I have looked into all available options in BestSync and cannot see any indication for taking daylight Saving into account.
- System
- Provider
[ Name] Application Hang
- EventID 1002
[ Qualifiers] 0
Level 2
Task 101
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-08-28T22:36:35.000000000Z
EventRecordID 5241
Channel Application
Computer sftp2
Security
- EventData
BestSyncApp.exe
9.0.6.2
bb8
01cfc30e82fd23a9
122
C:\Program Files\RiseFly\BestSync\BestSyncApp.exe
c2bd59a7-2f03-11e4-80e5-005056a915d4
55006E006B006E006F0077006E0000000000
Binary data:
In Words
0000: 006E0055 006E006B 0077006F 0000006E
0010: 0000
In Bytes
0000: 55 00 6E 00 6B 00 6E 00 U.n.k.n.
0008: 6F 00 77 00 6E 00 00 00 o.w.n...
0010: 00 00 ..
Regards
Brett
Daylight Saving Issue
Re: Daylight Saving Issue
BestSync has the following option to handling the daylight saving time change:
[attachment=0]DaylightSaving.png[/attachment]
BestSync should not have problem when handling daylight saving time change. If you think there is problem. Please try BestSync 2015 beta at the download page to see if the problem can be resolved.
- Daylight Saving
- DaylightSaving.png (30.44 KiB) Viewed 5907 times
