some subfolder don't sync
jondsam
Post by jondsam »
I have a directory with files and 3 subfolders. The files and one subfolder sync with google drive, but two subfolders get uploaded but not down synced to second computer.
Using 2015 Beta. Any ideas? And note still having problem with excel files requiring "repair" after syncing.
Thank you.
Re: some subfolder don't sync
If you start the preview of the task, is there any error string in the result column?
If there is any error, could you please copy the log text of the log windows at the bottom of the preview window, then post the text here?
