hello:
when i attempt to connect to webdav site, i receive the following message:
"Failed to send request.(A certificate is required to complete client authentication)"
see attached screenshot. how do i enter/provide the certificate or bypass this message?
thank you.
certificate for webdav access
- screenshot of error message.
- webdav certificate-9-30-2014 11-46-49.png (97.38 KiB) Viewed 8341 times
Re: certificate for webdav access
BestSync uses the certificate store of Windows system.
You can install your certificate (from the WEBDAV server) to the "Trusted Root Certification Authorities" node of the certificate store. (Just double click the certificate, refer to the this link (http://www.risefly.com/help/wzftps.htm) to install the certificate.)
thank you for responding.
according the instructions on the page of the link that you posted, a popup dialog should appear. in my situation, no dialog popup appears. also, the instructions in the link refer to ftp. my situation is webdav. does that make a difference?
The certificate store of webdav and FTP is same, the point is that you need to install the certificate to "Trusted Root Certification Authorities" node of the certificate store, though the User interface may be different.
