Log shows failure, files seem to have synced
bbegy@spotlite.com
Post by bbegy@spotlite.com »
My log shows the following:
,Ver9.0.6.2
Wednesday, October 1, 2014 15:55:13 [==>Success:2 Failed:2 Completed Size:16.76 MB]
Y:\Backup\ ==> s3:///[MY_S3_BUCKET]/iad/rdb/
Action,File,Time,Size,Result,Backup
Move 1-->2,\PDB-40914-01\RecordShop\LOG\PDB-40914-01_RecordShop_LOG_20141001_153001.trn, 10/1/2014 15:30:01,8525312,Success,Success
Move 1-->2,\PDB-40914-01\RecordShop\LOG\PDB-40914-01_RecordShop_LOG_20141001_154500.trn, 10/1/2014 15:45:00,9054720,Success,Success
Success,2
Failed,2
Completed Size,17580032
It looks like 2 files succeeded and 2 files failed. But which files failed?
Re: Log shows failure, files seem to have synced
You can start the log view of the task to see what files were failed, and what kind of error happened.
dhamilton
Post by dhamilton »
I am experiencing the same issue with one of my users. Job shows 3 successes, 3 failures. All files appear to have synched, and log view shows no more information than 3 successes, 3 failures. Is there a way to get a more verbose error log to see what triggered the failures? Running BestSync 2015 (10.1.0.3)
Thank you.
arjanm
Post by arjanm »
lookslike the same problem we have...(problem3)
http://www.risefly.com/forrum/viewtopic.php?f=2&t=1016
If real-time sync option is selected, BestSync just counts all the successful and failed results, and it does not clear the failed count when a file is successfully synchronized after retry.
