Failing Read Only
jrebele
Failing Read Only
Post by jrebele »
Folks,
I just purchased BestSync. The product works great. I am synchronizing a webserver file system that is 39GB. I am only going one-way, down to back up the server files. Things go fine and then all of a sudden BestSync starts throwing the following error message for almost every file:
1==>2
OpenFile:
sftpOpenFile:
remotePath: /xxxxxx/xxxxxx/public_html/administrator/language/en-US/en-US.com_categories.sys.ini
access: readOnly
createDisposition: openExisting
v3Flags: 0x1
Sen
What I can tell you is all folders have a permission of 755 and files have permission of 644. I am connected via SFTP with the root account. I am not sure how I get around this issue. I have 8 simultaneous downloads running. Any thoughts on how I resolve this issue?
Thanks,
Joe
Re: Failing Read Only
Could you please tel me whether the task uploads files to the SFTP server, or downloads files from the SFTP server?
jrebele
Post by jrebele »
I'm downloading from the server.
thanks,
Joe
Please check if you have unchecked "Protect read-only file from being deleted or modified." option in "Copy Options" setting tab.
jrebele
Post by jrebele »
Yes. It is unchecked.
jrebele
Post by jrebele »
This is still failing with the Read-only disabled. Any way to email you the project file so you can try it?
Thanks,
Joe
Could you please export the task to file, then send it to risefly@risefly.com.
