(1). Select "Microsoft Azure" in the "File System" list.
(2). Setup the parameters for connecting to the Microsoft Azure server.
Account: The Storage account of Microsoft Azure.
The storage account is shown on the "Access Key" page of Storage Account of Microsoft Azure.
Access Key: like "H0OlXXXXXXXXXXXXXXX/AZIpLDXXXXXXXXXXXXXXXXXXTQhECR8b+g0XXXXXXXXXXXXXXXXXXXXXviqNQDM" (about 104 characters).
The Access Key is shown on the "Access Key" page of Storage Account of Microsoft Azure.
If the local computer is behind a firewall or NAT, usually the computer needs the proxy to connect to the Microsoft Azure server.
Advanced...:
Setup the customized meta-data to the file that upload to the Microsoft Azure.
(3). After set up the parameters above, press "Go" button to connect to the Microsoft Azure server, and list the containers into the tree view.
The log window below the treeview logs all the commands sent to the Microsoft Azure server, and responses from the Microsoft Azure server. If the connection between BestSync and Microsoft Azure server can not be established successfully, please check the log.
