(1). Select "File Folder" in the "File System" list.
"Desktop" and "My computer" will be added to the treeview automatically.(2). Select a folder that you want to be synchronized.
If a folder has not been expanded in the tree view, press the "+" mini button at the left of the folder will expand the folder and show all its children folders.(3). Click "OK" button to end the dialog box
